Use 2 Akai APC mini
rudi
Real Name: Rudi Donné
DESIGNFactory wrote:File attached
though i tested on 2 windows 7 systems (32 & 64 bit)
and the laptop i use on shows with windows 10 64bit
all systems show the same errors....
thanks, any help is deeply appreciated :)
note: one way to avoid the crash is to NOT send feedback to controler .
Thanks for the workaround but it's strange sending feedback to non-motorised faders...
DESIGNFactory
Real Name: John Yiannikakis
i send feedback only to buttons, the APC mini can light the buttons in 3 colors + flashing ... makes it easy to see what is playing
there is only "input" in QLC's faders.... oups...i hope there is no hidden "feedback" sent in the software :) is there? that would be a bug
antoinelgh
Real Name: Antoine THOMAS
So have you succeed using two midi controller for one show?
I need it for a show in two weeks :)
also i will use a USB HUB with external power supply to see if it comes from an over consumption of power on USB. ( as 2 midi controller with feedback and lite buttons are consuming too much for a laptop I think).
antoinelgh
Just to conclude this topic, i use two akai apc mini on two separate universe and it works perfectly ;)
