DMXKing UltraDMX2 Pro
Tammuz
Real Name: Thom Tisher
Post by Tammuz » Tue Oct 31, 2017 5:11 am
I'm struggling to get my new DMXKing UltraDMX2 Pro controller working with QLC. The software picks it up as DMX USB PRO which is great. When I configure the plugin to Ultra Pro because the device is setup for two outputs, red lights start flashing on the controller. The only channel that works in Simple Desk is 3 which adjusts the cycle speed as the PAR cycles through colours. The only settings in the config plugin window that doesn't make the red lights flash is Open TX and DMX4ALL, but then I can't get the light to work at all.
Also, the software starts to run very slowly as I try to mess around with permutations of settings. I suspect this is because the software is struggling to communicate with the controller.
I've installed version 4.11.1 of QLC with the FTD2xx drivers on a Windows 7 x64 platform. The light I"m trying to control is an Orion Orcan 2 with 7 channels.
