MIDI Encoder/Knob
pinq
MIDI Encoder/Knob
Post by pinq » Mon May 22, 2017 6:26 pm
Hi all!
I just started to use QLC+ and it is great. Works like plug and play method.
But, I have problem. I have Behringer CMD LC-1 MIDI controller that has knobs and buttons. You can rotate the knobs around as much you want, so they are relative. I also record with KMidimon what values the knobs send. When I turn it right it sends 65 value and when right it sends 63.
Problem is that I can get them relative mod. Input profile editor finds the knobs automatically and I set it to encoder/knob. But then When I try it virtual consol as knob, it doesn't work. It only show the half value.
Other thing, not really a problem, is that it is possible to change buttons colors if I want, but I have to edit the MIDI output to make it work. Any idea how can I edit that?
Thank you
pinq
Re: MIDI Encoder/Knob
Post by pinq » Mon Jun 19, 2017 10:57 am
Ok, I got colors working by adding feedback value for buttons.
Example if you want that your button is green when it is not in use and blinking green when it is use, you just add min feedback value to 2 and max value to 4.
Apparently you have to calculate the knobs value your self in other program and then send it to Qlight control + :?
