i'm using a USB to DMX adapter (with a FTDI FT232RL chip) and Linux (Ubuntu 16.04 LTS).
Every about 1 minute or more, the adapter stops sending data to DMX for about 5 seconds causing a blackout, than starts working again.
This happens also with nothing connected, with only the line terminator.
Can you help me in undesrtanding as to solve this problem?
USB to DMX - blackout
- sbenejam
Antonio, can you post more details, from your Ubuntu system logs and your USB FTDI adapter?.AntonioDB wrote:Hello,
Antonio,
can you observe your system to check if there are no CPU usage peaks? USB-DMX adapters without microprocessor (e.g. Enttec USB DMX pro has one, Open DMX doesn't) are sensitive to CPU usage.
If some other program uses all CPU, QLC+ can't do its thing.
Does the DMX monitor show correct data?
Is QLC+ user interface responsible during the blackout?
- sbenejam
I tested this morning QLC+ with my USB RS-485 FTDI dongle and all worked well on a Xubuntu 16.04.AntonioDB wrote:Hello,
