Hi all,
My plan with qlc was to input from an Enttec Pro, then output over sACN. The sACN Works fine (Tested to four universes) but the Input from the Enttec keeps crashing QLC+. For the record, the computer is a Surface Pro 3 with an i5 and 4gb RAM and I am running the latest version. QLC is fine with selecting the Enttec as an input on Universe 1, but as soon as I send it DMX it crashes. Any help would be great. If you need more info don't hesitate to ask.
Thanks,
Liam
DMX In Form ENTTEC Pro Crashing
There was indeed a bug. I have reproduced and fixed it now. Tested with a Enttec PRO MK2 and a DMXKing ultraDMX Pro.
Please check the latest Windows TEST build here: viewtopic.php?f=12&t=3135
Please also report here if that fixes the issue you've had.
Are you sure you're using the test version ?
Better to uninstall QLC+ first and intall a new one from a clean state
