I'm using QLC+ in combination with SuperCollider to drive some effects based on audio input (and to do some modulation/playback stuff at the same time). I'm using SuperCollider to send OSC messages to QLC+ - everything works great, except after a few moments, QLC+ appears to stop receiving OSC packets (sometimes after a few hundred, sometimes after as many as a few thousand). looking at the OSC line in the 'inputs/outputs/ window, the packet count stops going up. If I uncheck the 'input' box and recheck it, it starts working again for a few moments.
I'm currently sending several packets a second.
OSC packets dropped
4.9.1 is almost one year old.
Please try with 4.10.4 as several fixes/improvements have been done on the OSC plugin
