BUG chaser inside a chaser
Posted: Thu Jan 19, 2017 12:52 pm
by maximortal
version 10.4.6.86
Probably is a bug not only in this version
as you can see in workspace attached i placed a chaser inside another chaser (this is usually done in theatre where the outside chaser is the whole show and the chaser inside is a "special FX" )
if you trigger steps of the outside chasers using the go key behaviour is uncorrect...in particular fade time of inside chaser is totally wrong.
The funny stuff is that if you fade between steps using faders (link and mix enabeled) it works fine
Re: BUG chaser inside a chaser
Posted: Thu Jan 19, 2017 2:03 pm
version 10.4.6.86 doesn't exist.
I didn't read the rest
