Audio File Path Duplication
serenss
Real Name: Daniel
Had a search for this problem, but couldn't find anything.
I'm having an issue with wav files in the Function Manager in that the correct path will be, e.g.: /Users/username/BackingTracks/CBTL.wav
These audio files will run fine until I close the QLC+ file and reopen, where the path in Functions -> Audio will become, e.g.: /Users/username/Users/username/Users/username/BackingTracks/CBTL.wav
And the wav file becomes unlinked.
Many thanks.
Dan.
Version 4.10.3a on OSX 10.11.4 (El Capitan).
can you post your qxw file after first save? Create new qxw, add the wav file, save, and attach here.
Also please post the path where the qxw is stored in your computer.
(I'm trying to find out if the problem is in saving or loading -- if the path is ok in qxw, the problem is in loading...)
