Just installed 4.10.3 and now I can't load/play any audio files?
All my existing SFX / wav files don't play.
Trying to reload audio files I get a message box :
Unsupported Audio file :
This Audio file cannot be played with QLC.
This is with .wav, .mp3, .ogg etc.
Am I missing something?
Linux Mint
[FIXED] Linux/Qt4 - 4.10.3 Audio not working
Which package are you using ? From qlcplus.org or automated builds ?
Qt4 or Qt5 ? 32 or 64 bit ?
I suggest to uninstall 4.10.2/4.10.3 and install 4.10.3 from fresh.
Some paths have changed and audio decoders have become separate plugins
Uhm...there is indeed something wrong. I just installed the same package you tried on Ubuntu where QLC+ has never been installed.
And got the same error on audio files.
All the files seem to be in the right place but it just doesn't work.
I tried also with a package built by OBS and the same happens
I'll have a look later tonight to understand what's going on
Thanks for spotting
Thanks for spotting
Yeah sorry guys.
It is a release only issue (in debug mode it doesn't happen) and most likely it is related only to Qt4 and only to Linux.
I am investigating it but it doesn't seem to be trivial to fix.
Will keep you posted here.
Thanks for checking Giacomogiacomo wrote:I can confirm, I tested 4.10.3 qt5 on linux arch 64bit and I've not seen sound problems.
- sbenejam
Tested on Xubuntu 15.10. qlcplus:4.10.3 QT4 version loading audio don't work I get this error "This audio file cannot be played with QLC+". With an workspace with audio files audio don't play. Qt5 version plays audio without problems.
One more thing, on open audio file window on Qt4 Files of type: shows Audio Files(), on Qt5 Audio files(*.mp3 *.aiff *.aifc *.flac *,oga *.ogg *.flac).
Yes, because extensions come from the audio decoding plugins now. If they are not loaded, the list is empty as well.One more thing, on open audio file window on Qt4 Files of type: shows Audio Files(), on Qt5 Audio files(*.mp3 *.aiff *.aifc *.flac *,oga *.ogg *.flac).
Damn it, you're right !crackley wrote:Doesn't appear to just be a Linux issue. I'm seeing the same thing on OSX 10.10.5
Luckily that was trivial to fix. I just uploaded 4.10.3a: http://www.qlcplus.org/downloads/4.10.3 ... .10.3a.dmg
Linux Qt4 builds should be fixed as well now.
I just uploaded 4.10.3a packages: http://www.qlcplus.org/downloads.html
Please confirm it is fixed and I'll mark this thread as FIXED.
- forresthopkinsa
Well, I'm on Lubuntu using 4.10.3a/Qt5 and, while I can import audio files, they do not play.
I also have the issue that, when selecting audio files, the file explorer only shows to open with "Audio Files" rather than the filetypes.
The Audio I/O Panel's "Level Monitor" is at 0% continuously. I don't know if that helps.
I am able to successfully open the files through other programs like Audacity and MPlayer.
"Preview Stereo Channels" correctly analyzes the file.
Production Director for Coastline Church NW
Software Engineer at AWS S3
