SETUP:
QLC+ 4.10.3 TEST
I have setup a show with a video.
I have may laptop (win 10) setup with an 2nd screen attached to a VGA output (extended display setup for projection).
I have setup the video of my show to be played FUL SCREEN on SECOND screen (to simulate the video projector).
PROBLEM:
- when I open the qxw and play my show, the video is played FULL SCREEN but on the FIRST SCREEN (the main one where I control QLC+ ) and I just can't stop anything till the end of the show.
WORKAROUND:
I play all my shows once first with the button "windowed" thick for screen 2.
Then I can thick the FULL SCREEN button and it is OK.
No qxw provided because a video is involved.
Tell me I you need one anyway.
Many thanks to everyone for all your support
[SOLVED] [Windows] Video does not open in the correct screen
Enttec DMX USB Pro
Windows 10
Windows 10
Can someone have a look to my issue and tell me if that is a normal behavior or a bug ? ?
Enttec DMX USB Pro
Windows 10
Windows 10
I'd guess it's a bug. I don't use video, so I don't have experiences in this area. It may turn out it's QLC+ bug but it may as well be a bug in Qt or windows.
I think I've seen it before, and unfortunately it depends on the Qt libraries.
I think I also tried to workaround it, without luck.
I'll try again when I'll have some time.
please try this and let me know if it is fixed
viewtopic.php?f=12&t=3135
TKS mcallegari.
I am looking at it.
I have just switch to linux, and, if I the 4.10.3 install was quite easy ( ny first try with an ubuntu distrib), I do have trouble to install that latest one 4.10.4.
I'll keep on trying.
I'll tell you for windows 10 also soon.
I am looking at it.
Enttec DMX USB Pro
Windows 10
Windows 10
The Linux version doesn't have the video positioning issue. Even version 4.10.3a.willmodelisme wrote:I have just switch to linux, and, if I the 4.10.3 install was quite easy ( ny first try with an ubuntu distrib), I do have trouble to install that latest one 4.10.4.
Please let's stay on topic and focus on the Windows version
I know Massimo
I was just trying to tell that I "definitely" switch to linux when using QLC+ ( with open speech about my difficulties to install QLC+, but I agree, it's off topics, just disregard).
Anyway, I install it to my windows 10 PC for checking (and because I opened this topic) and so far so good it work like a charm.
Many tks again for your work.
Enttec DMX USB Pro
Windows 10
Windows 10
