Hi, first of all thanks for your big software......it is amazing!
I'm using QLC+ for my band and also for theaters show.
I found a issue when started to use the new QLC+ V4.11.1:
I converted the old work in new one as recommended by you.
In function section there are some collectors (collected some scenes together); after conversion from V4.10.5b to the new one, the collectors don't work and don't work in virtual console section.
I tried to create a new one collector but also in this case it doesn't work, please let me know if I'm doing something wrong.
Thanks in advance for your kindly support.
Collectors don't work in QLC+ 4.11.1
- Real Name: Boris
here in attached you can find my work, if you go in Virtual console section, switch to operate mode, open the monitor and push the A#-1 button .... nothing happens.
The button A#-1 is a collector with scene nr. 12 + 13 that you can find in function section...
Please try and let me know your comments.
- Prova_migrated.qxw
- (151.28 KiB) Downloaded 101 times
1- there's no such "A#-1" button
2- It's 'Collections", not 'Collectors'
3- you placed everything in a solo frame, so clicking button 18 (that's the one) starts functions 12 and 13, that get immediately disabled cause there are also buttons 12 and 13 in the same (exclusive) frame
I think you need to review your QLC+ workflow before saying "don't work".
- Real Name: Boris
thanks for your answers,
1- yes you are right the button name is "18" no "A#-1" the reason is because I usually add a picture in the botton...
2- again, yes you are right the correct word is collection no collector...sorry!
3- sure, I'll try to review my work flow.
anyway, only for your information as you can see in the attached file, before migration, my work works correctly with QLC+ 4.10.5b and all buttons are in the "solo frame".
- Prova.qxw
- (160.91 KiB) Downloaded 103 times
Please have a look at this:
viewtopic.php?f=17&t=11326
