[RESOLVED] I can't find the VIDEO FONCTION.
Posted: Sat Sep 30, 2017 5:05 pm
by Brouno
Hello !
I would like to use video in qlcplus, but the fonction is not available in the software.
Someone told me that I could add video from my local disk by using the fonction tab and clicking on the video icon ( near the ADD MUSIC )
But there is no ADD VIDEO icon there.
Am I doing something wrong ?
I'm using the 4.11.0 on a ubuntu 16.04 LTS
Thx for your help
Bruno
Re: I can't find the VIDEO FONCTION.
Posted: Sat Sep 30, 2017 5:34 pm
by sbenejam
Video function on Linux system is only available on QLC+ Qt5 versions. Install QLC+ Qt5 version or build with Qt5.
https://github.com/mcallegari/qlcplus/w ... -build-Qt5
Posted: Sat Sep 30, 2017 6:29 pm
by Brouno
Waw !
Thank you very much.
Bruno
Posted: Sun Oct 01, 2017 10:32 am
by Brouno
Hi !
I have a new problem ... When i start a video with qlc plus. A black screen window opened but nothing else happen.
Is there a package of codecs that i have to dowload to use the feature ?
Thanx again
Bru
Posted: Sun Oct 01, 2017 4:10 pm
by Brouno
Hi !
Someone told me that his version of QLCPLUS 4.11 use the 5.5.9 version of QT.
Mine is 5.5.1, is there anything that could give problem on my QLC PLUS Version ???
Thank you
Bru
Posted: Sun Oct 01, 2017 4:32 pm
by sbenejam
My system Xubuntu 16.04 Qt 5.9.2 from Qt website QLC+ 4.11 build from sources. Default Qt5 version in Ubuntu 16.04 don't have Gstreamer.1-0 support. On Ubuntu 17.04 QLC+ works well Qt5 version has Gstreamer.1-0 support.
Search other posts in this forums this has discussed before in the forums.
Posted: Sun Oct 01, 2017 4:53 pm
by Brouno
Ok, so i need to install QT 5.9.1.
i found the installer at the QT website, i did the install but when i'm startarting QLCPLUS it's still 5.5.1 in use ...
What's wrong ?
I'm running the QLC PLUS - QT 5 version that i found on the QLC PLUS website.
This version is XUBUNTU 16.04.
Do you think that this thing could give problems ?
Thx
Bru
Posted: Sun Oct 01, 2017 6:26 pm
by sbenejam
Instructions to build QLC+ from sources. https://github.com/mcallegari/qlcplus/w ... -build-Qt5
Change make with /home/your_user/Qt/5.9.1/gcc_64/bin/qmake
Posted: Sun Oct 01, 2017 6:56 pm
by Brouno
Ok, i will try to install QLC with this tuto.
But coud you explain to me what's the différence between the QT5 release installation and the sources code installation ?
It's not the same program ?
Bru
Posted: Mon Oct 02, 2017 6:27 pm
by sbenejam
QLC+ Qt5 version on Ubuntu 17.04 video works as expected. Maybe you can upgrade your Ubuntu system to 17.04 and you can use QLC+ 4.11 Qt5 deb package from qlcplus.org downloads.
Posted: Tue Oct 03, 2017 8:57 pm
by Brouno
Hi !
Ok, someone did the things for me ...
Now i'm running a QLC+ 4.11 with QT 5.9.1 and i CAN play vidéo.
That's wonderful !!!
Thank you very much
Bruno
