Controlling lights from the Functions Tab
BigD
Real Name: Dwayne Dorsey
I just installed QLC+ 4.11.1 on a Debian 9 computer. I have an Enttec DMX USB Pro Mk2 interface. I have 3 strings of 50 bulb dumb RGB led lights. I have three 3 channel DMX controllers.
I followed the youtube videos for QLC+ and setup the fixtures (I chose the Generic RGB fixture) and the system recognized the Enttech DMX controller.
I setup four groups Red, Green, Blue, and White. From the Simple Desk Tab I can control the lights both individually as well as the groups
I use the Second youtube video for Fixtures and Groups. I create a test scene and add the fixture I created from the first video. When I click on the tab for either Channels Groups for All Fixtures I cannot manage the lights with the faders. All the fixture channels are enabled.
If I go back to the Simple Desk tab, I can manage the lights with the faders.
At this point I am not sure if something was over looked. Is there something I am over-looking
Your help is appreciated.
PS the string lights are RGB with Red, Green, Blue and White (the Positive signal) cables
Welcome to the forum,
The cue you made is a preparation step... into the marvelous world of QLC+
You'd have to 'assign' this cue to something else.
Try following: (as per video #4 saying out by memory)
go to Virtual console
put a button on it
assign the button behaviour to the cue you composed earlier
run the show
press button -> lights go on, press again -> lights go off.
