4.10.5b: Editing a Matrix type causes crash
DESIGNFactory
Real Name: John Yiannikakis
First of all, this software has made my work a pleasure :D
Thank you , thank you , thank you !!!
the problem: While on live edit , i go to edit a matrix running ...particularly on ADJ Ultrabar 12's
for example a gradient(colors) or other type
as soon as i change the matrix type to "bitmap" the program crashes
Happens only on the new version, and since i see that you have modified the code for matrixes, any idea how to work around this?
PNEYMATIKO.qxw
The file i am currently working on
(127.06 KiB) Downloaded 63 times
Which OS are you using ?
