EFX not working in 4.10.5b
Bennosch
I use EFX functions for my LightmaXX Easy Wash QUAD LED (self-made fixture). They have been working well with 4.10.4 and 4.10.3 (not tested older releases), but now with 4.10.5b they do not move anymore. All movements and other functions aside the EFX functions are still working properly with the moving heads, that's why I think the fixture must be ok. I have tried to create new EFX functions already and that does not work either.
Any idea?
Thanks and best regards
Ben
Please post your custom fixture, your workspace and the steps to reproduce the issue you're seeing.
Saying "it doesn't work" doesn't help much
Bennosch
Here you go, thanks
Amplifiers DH.qxw
(295.94 KiB) Downloaded 65 times
LightmaXX-Easy-Wash-QUAD-LED-V.2.0.qxf
(4.73 KiB) Downloaded 69 times
Bennosch
Ah and "by the way": I use Windows 10 with the Enttec Open DMX USB Interface.
As I suspected, your fixture is messed up.
Check it with the online fixture validator: http://www.qlcplus.org/fixture_validator.php
There are 8 errors.
Previous QLC+ versions allowed a bad usage of Pan/Tilt fine. 4.10.5b doesn't allow it anymore. The definition must be correct.
P.S. "Ran/Tilt Speed"...really ? "Movment" ?
Bennosch
Yes there are some typos, thanks for reminding me. The fixture validates now and I will try again later when I am in the studio.
The online validator is really helpful, I was not aware of it.
Thank you so much!
Bennosch
Just to let you know: It is working now in 4.10.5b!
Thanks again and best regards
Ben
