Crash when trying to delete an audio function
mitscherdinger
Hi there!
System: Lenovo Thinkpad R61, Core2Duo-CPU, 2 GB RAM, 64bit-Ubuntu-Gnome 16.04, QLC+ 4.10.4 (QT5)
Created 3 Audio-Functions with WAV-files. When I try to delete one of them (or all together), QLC+ crashes.
Tried to install debugging symbols from the opensuse.org-repository, but unfortunately qlcplus-qt5-dbg 4.10.4 depends on qlcplus 4.10.4, which isn't there. (Guess, it should have been qlcplus-qt5 4.10.4, instead, so: please update the repo to get more info. :) )
Mitsch
mitscherdinger
mitscherdinger wrote:Tried to install debugging symbols from the opensuse.org-repository, but unfortunately qlcplus-qt5-dbg 4.10.4 depends on qlcplus 4.10.4, which isn't there.
Same problem btw with qlcplus-qt4-dbg. It depends on qlcplus but should be depending on qlcplus-qt4.
Greets!
mitscherdinger
…and another prob with the repositories: You can't install different qlc-versions side by side - not because the versions collide in f.e. aptitude but because all versions try to write
/etc/udev/rules.d/z65-dmxusb.rules
which will be prevented by dpkg.
Greets!
