RGBWA Fixtures dont copy
rohanwright
Real Name: Rohan Wright
If i try copy parameters from one fixture to another with anything that has RGBW or RGBWA then the RGB copies over but the W and A don't. Its been like this for a number of years even after updates.
A little bit poor for an issue report.
What are the "parameters" you're talking about ? Maybe you meant "channel values" ?
From where to where are you copying stuff ? Scene Editor ?
Are you using per-channel copy by pressing the CTRL key on a channel or are you using the color tool ?
Please improve, otherwise we can't help
