import machine in a function, lack of CH 12
pliz
Real Name: Julien
Hello everyone,
I have a little problem on the software. I create a fixture 13 CH. I standard features in the software no problem 13 CH are present.
The problem occurs when I want to create a new stage and I import the machine, I miss the channel 12.
Is there a solution?
thank you
FR:
Bonjour a tous,
j'ai un petit probleme sur le logiciel. je crée une fixture 13 CH. Je l'inporte dans le logiciel pas de probleme les 13 CH sont présent.
Le probleme survient quand je veux créé un nouvelle scene et que j'importe l'appareil, il me manque le channel 12.
Existe t il une solution ?
merci
plugz
Real Name: David
Please post your fixture file and the workspace file you created with it.
Thank you
pliz
Real Name: Julien
attached the files
Generic-Mini-wash-7x10W.qxf
(3.94 KiB) Downloaded 92 times
essai.qxw
(1.69 KiB) Downloaded 82 times
plugz
Real Name: David
Thank you. Same thing happens for me too.
janosvitok
Real Name: Jano Svitok
I suspect that the problem is that channel 12 has group "nothing". Change it to anything else, like maintenance and check if it helps.
In addition, change group byte of pan/tilt fine channels to LSB.
pliz
Real Name: Julien
Janosvitok thank you,
The problem is that the channel 12 was in "nothing."
thank you for helping out
