4.11.0 chaser with nested functions bug
maximortal
Real Name: Iro Suraci
I found another bug about chasers (4.11.0) very similar to another one reported by me few days ago.
if you put a sequence nested into a chaser it don't works properly. If in parent chaser the step where i've placed sequence have a fade in/out time it's applied to every steps of the nested sequence.
Nest bug 2.qxw
(6.44 KiB) Downloaded 71 times
Was it working as you expected in 4.10.x ?
maximortal
No, is an issue also in previous versions (i can't say from which one)
