[SOLVED] Chauvet 6 Spot not responding to scene button in virtual console
The issues found when using the Fixture Manager panel
Big-D
Real Name: darrin pinegar
Hello everyone so I am pretty new to QLC + and I am having an issue when I add a Chauvet 6 Spot to a scene When I create a button for the scene on the virtual console it will turn on the fixture but will not turn it off Can someone tell me what I could be doing wrong
plugz
Real Name: David
Most probably because you're changing an LTP channel.
Please share the workspace file so we can be sure of this.
Big-D
Ok I’m embarrassed to admit that I’m not sure what you are asking
yokosuna
HTH...
plugz
Real Name: David
Big-D
First of all thanks for the response I hope this is what you are looking for
plugz
Real Name: David
Nope, the workspace file is the .qxw file, this is what would help.
It's the file you create when you click "save as..." in QLC+.
Big-D
6 Spot Test.qxw
(2.65 KiB) Downloaded 110 times
Sorry about that Here is what you are looking for
plugz
Real Name: David
All the channels of the 6-spot are LTP.
see http://qlcplus.org/docs/concept.html
An LTP channel will keep the last value is has been set to.
To let the channel go back to its previous value, you can have a "background" function that sets all the channels to 0, and have this function always running.
Or you can set the channels to HTP if you're OK with an HTP channel behavior.
Big-D
Thanks I will try both of those and let you know what I find
Big-D
Changing all the channels to HTP fixed my issue thanks for the help
