[SOLVED] Chauvet 6 Spot not responding to scene button in virtual console
- Real Name: darrin pinegar
Hello everyone so I am pretty new to QLC + and I am having an issue when I add a Chauvet 6 Spot to a scene When I create a button for the scene on the virtual console it will turn on the fixture but will not turn it off Can someone tell me what I could be doing wrong
- Real Name: David
- Real Name: David
All the channels of the 6-spot are LTP.
see http://qlcplus.org/docs/concept.html
An LTP channel will keep the last value is has been set to.
To let the channel go back to its previous value, you can have a "background" function that sets all the channels to 0, and have this function always running.
Or you can set the channels to HTP if you're OK with an HTP channel behavior.
