fade in time in chasers
The issues found when using the Fixture Manager panel
dennismazzolin
Real Name: dennis mazzolin
Post by dennismazzolin » Mon Apr 24, 2017 12:14 pm
in virtual consolle, chaser that associate in a single fader not respect fade in time scene. if chaser are added in cue list or botton it work good.
mdmayfield
Real Name: Matt Mayfield
Re: fade in time in chasers
Post by mdmayfield » Mon Apr 24, 2017 2:15 pm
I've seen this as well, and so far have worked around it by using a Submaster fader in a frame with a Cue List for the chaser.
It almost seems like the fader widget is using the same mechanism that fade-ins and fade-outs do, which overrides the entire fade time. If for example the fader is set to 80%, then instead of fading from 0% - 100% over x seconds, instead the chaser step scene is immediately set at 80% (as if 0ms fade time).
Also, there is a cascading effect when using nested chases / cue lists. If the parent chaser (which is attached to a fader widget) contains another chaser (not attached to a fader widget), the child chaser will also not be able to fade.
