QLC+ 4.8.3 release
Massimo Callegari
QLC+ 4.8.3 release
Post by Massimo Callegari » Sun Dec 21, 2014 1:55 am
All I can say is: WOW ! QLC+ 4.8.3 ended up being another massive release of this project.
As you can see from the changelog, another big set of fixes and improvements have been addressed to increase the stability and the functionalities of QLC+.
In random order:
* The animation widget can now count also on individual RGB knobs. For this and many other improvements we need to thank David Garyga that has now became part of the QLC+ development team !
* The Script function, this obscure part of QLC+, is now documented and has been improved. You can already achieve nice results with the random() macro and by calling external programs/scripts
* Major rework of video playback and added the possibility to stream a video from the network. Unless major drawbacks come out, videos should be now usable for production purposes
* Reworked audio triggers to allow multiple instances at the same time and with a different number of spectrum bars. Also, if placed in solo frames, they acquire the typical exclusive behaviour
* A massive 31 new fixtures ! Thanks in particular to Thierry Rodolfo. Half of the new fixtures are his
I wish you a Merry Christmas and a happy new year.
Changelog:
* Engine/UI: Fixed and improved the Script Function. Please see the documentation
* Virtual Console/Animation: added end color reset control
* Virtual Console/Animation: added R/G/B custom control knobs for start and end colors (David Garyga)
* Virtual Console/Audio Triggers: fix crash when changing the input device while a trigger is running (David Garyga)
* Virtual Console/Audio Triggers: fixed incorrect number of bars when reconfiguring the widget
* Virtual Console/Audio Triggers: multiple triggers at the same time and with different number of bars are now supported
* Virtual Console/Frames: added option to hide the enable/disable button (David Garyga)
* Virtual Console/Knobs: now they can be inverted like sliders (Jano Svitok)
* Virtual Console/Sliders: fix inverted monitor value (David Garyga)
* Virtual Console/Live Edit: fix some widgets state when live editing (David Garyga)
* Virtual Console/Solo Frames: can have multiple widgets associated to the same function (David Garyga)
* Engine: It is now possible to set a network URL on videos
* Engine: fixed channels forced to HTP/LTP multiple times
* Engine: fixed universe passthrough flag not restored on project load
* Fixture Manager: recompute address overlap when fixture mode changes (Jano Svitok)
* Scene Editor: Channel's primary color rather than its name is used to determine Color Tool availability (Jano Svitok)
* RGB Matrix Editor: correctly update colors when the algorithm is changed
* UI: fixed time editing of milliseconds (.3 is 300ms and not 30ms)
* Plugins/ArtNet: fixed malformed output packets (4.8.2 regression)
* Webaccess: fix crash when trying to update a closed connection (David Garyga)
* Application: fix doc modified flag not set on widget deletion, cut/paste, and raise (David Garyga)
* New fixtures: Cameo LED Mini PAR CAN RGB 7x3W/RGBW 7x8W/White 7x4W (thanks to Joachim Wiedorn)
* New fixtures: Showtec Infinity iW 715 and iW 720 (thanks to uchris)
* New fixture: American DJ DJ Spot 250 (thanks to 007ghg7)
* New fixture: Blizzard Lighting Weather System (thanks to James Elliott)
* New fixtures: Starway AXIS 250 16Bits, FullKolor, NanoKolor, TourKolor, Servo Beam 5R (thanks to Thierry Rodolfo)
* New fixtures: DNA Pro Slim 18 RGBW, Martin MAC600 NT, Starway ServoColor 600, Starway ServoColor 800 (thanks to Thierry Rodolfo)
* New fixtures: Vari-Lite VL2500 Wash, Martin JEM K1 Hazer, Generic Smoke (thanks to Thierry Rodolfo)
* New fixtures: Martin Mac 2000 Profile II, Martin MAC Aura, PR Lighting PR 5000 Spot (thanks to Thierry Rodolfo)
* New fixture: Contest PSC-930 (thanks to Noel Utter)
* New fixtures: Eurolite LED CBB-3 COB RBG 3x15W Bar, lightmaXX Platinum Line Mini PAR QUAD 7x8W, Eurolite LED PMB-4 COB RGB 30W Bar (thanks to Thomas Demmel)
* New fixture: Pulse SlimLite 56 (thanks to Jimmy Traylor)
* New fixtures: Chauvet Intimidator Spot LED 150, Chauvet SlimPar Tri 7 IRC (thanks to Tavon Markov)
* New fixture: Showtec Expression 5000 (thanks to Joep Admiraal)
* New fixture: Eurolite LED PMB-8 COB RGB 30W (thanks to Thomas Achtner)
david garyga
QLC+ 4.8.3 release
Post by david garyga » Mon Dec 22, 2014 9:43 am
