I want my own pan/tilt chaser in the xy-pad. Now you can only choose from EFX or Scene.
Now, when I want to switch between the chaser and a scene in the XY-Pad, I have to urn off the chase before I turn on the scene.
The XY-Pad is really functional when I can adjust little positions and see the positions in my screen.
Chasers in XY-Pad configuration
Can you post an example qxw with such chaser?
- Real Name: Robin
Beweging 1 (dutch for "movement") is the chaser I want to use together with the XY-Pad so it switches between the chaser and the preset.
- Ayra-ERO-506.qxf
- My fixture
- (5.14 KiB) Downloaded 81 times
- IAG.qxw
- Project
- (35.99 KiB) Downloaded 101 times
