Change cues in cue list using pause button
filipek.o
Real Name: Filip
I do Have a list of position of movers in cue list and i Love this way of storing them using dump function, but i wish o could use a pause button in the way that it:
1. I go to a cue i want for exqmple cue 6
2. I want to jump to cue 8 in cue list
3. I click pause button so it frazes values of cue 6
And i can feely navigate to cue 8 and nothing is changing
4. I Have higlighted cue 8 and Press play again and it goes imidtilty to values stored in cue 8
Thank you can Please tell if this is possible
Filip
If you'd put a button for every cue into a solo frame in VC - you can easily jump from one to the other scene pressing the button
filipek.o
Real Name: Filip
But then i will Have to use a lot of buttons on conttoler and and i can esily dump values and Store them in cue so there is much more good things on using cue list
filipek.o
Real Name: Filip
looks like it is working in newest version I dint see it change log
