Reload most recent workspace on startup
matthijskooijman
Real Name: Matthijs Kooijman
Post by matthijskooijman » Mon Dec 04, 2017 9:09 am
Would it make sense to reload the last workspace when QLC+ is started? I would expect that you often work on the same workspace multiple times in succession, and I was surprised to start with a new workspace every time.
I realize that commandline parameters can be used to load a workspace on startup, which is great if you're working with multiple shows in parallel, but simply reloading the most recent show would probably be easy to implement, and seems very convenient to me.
