Hi all,
I was hoping for a feature where a flash button could temporarily over write the values of fixtures that are currently in place from a toggle button. For example,if there is a toggle button that has a dimmer at 107 but then a flash button temporarily changes it to 50 for example. Currently it would only work if the value in the flash button is higher than that in the toggle button
Flash Overwrite Toggle
Hi, what you described is exactly the behavior expected for HTP channels.
Modifying this would be breaking HTP, so I don't think this will ever be implemented.
If you know what you're doing, you can force those channels to be LTP instead.
