EFX relative Attribute
lcslouis
Real Name: Louis Gutenschwager
Post by lcslouis » Mon Jun 12, 2017 8:32 pm
The Attributes for EFX need the ability to disable or enable relative without having to edit the running function.
janosvitok
Real Name: Jano Svitok
Re: EFX relative Attribute
Post by janosvitok » Mon Jun 12, 2017 9:17 pm
Can you describe how would you use it?
lcslouis
Post by lcslouis » Sat Jun 24, 2017 8:00 pm
Well when I'm doing a show and I want the efx to have its relative disabled before i go to it.
so Initial state would be right click disable or right click enable depending on what the default efx state is
While it is running it would be which ever I set to
when the efx is stopped or I switch to a different one it should change back to its default.
