Speed Dial - Save Divide/Multiply Value
lorenzoandreani
Real Name: Lorenzo Andreani
It's possible to save the value of Divide/Multitply ?
Currently when close and re-open the show the value (of Divide/Multiply) returns to 1
I also need to set the "Duration factor (+ tap)" value on the Function tab to 32 (currently the maximum value is set to 16)
Last edited by lorenzoandreani on Sat Apr 29, 2017 11:51 pm, edited 1 time in total.
plugz
Real Name: David
(moved to feature request)
Both should be possible, I'll see what I can do.
