Renaming Hotkey
MontyZuma
Real Name: Klaus Muth
Plase add a hotkey (F2 is standard for that) for renaming whatever is hilited at the moment.
Most stuff requires klicking on the Properties Toolbutton (or double klicking it), some just require klicking on the item and change the name in the opening subwindow, in the Virtual Console it's rightklick + Properties or Ctrl-E, I found absolutely no way to rename a show without editing the .qxw and to rename a folder in the Functions Tab its just double klicking it and editing it in place.
That is just a little PITA in an otherwise really good designed user interface...
klaus
A Show can be renamed in the Function Manager by clicking on the Show, like every other QLC+ function
Please do not exagerate with requests if you don't know how the software works well enough.
As for F2...well, is QLC+ a file manager or something else ?
