Flash-Button for Submaster?
Chris De Rock
One little thing i miss: A flash-button for submaster-fader. Maybe as extra feature for the button widget or (harder to code) as component inside the fader widget. Is this possible?
This is already possible with the loopback plugin. Please have a look at the attached workspace.
flash submaster.qxw
(3.39 KiB) Downloaded 63 times
iamchrislaurie
Real Name: Chris Laurie
Hi Siegmund
This does not quite work:
Set slider to 125
Press & hold submaster flash button - slider goes to 255 - that is good.
Release the flash button - slider goes to 0
Currently the script engine does not cater for reading a channel value and storing it somewhere to use later. I suspect on top of that it would also need the ability to execute a function (script) on the release of a button.
You're right, sorry I just quick tested it with 0 as initial value.
Yeah, some additional features in the script function would be great. In the meantime, you could work around the issue with an additional fader:
flash submaster.qxw
(4.05 KiB) Downloaded 82 times
