Multipage frame with external controller - catch slider by value
caxpern
Real Name: Casper
Works good when switching pages, but not after you press the Override reset button, then it still jumps up! Its not i big deal, but im trying if i an use this button as a clear button (like in Gradma and others). Thanx for all the work!
Good "catch" :D
I've fixed this in git!
janosvitok wrote:- maybe you can catch faster movement of external fader if you check not only when they are (almost) equal, but if the fader crosses the value (either slider was above and now is below the value, or vice versa)
I'm not shure how hard/easy is to implement. You'd need to handle movement of the on-screen fader -- most probably start the catch algorithm from scratch.
I was able to implement this. Still I don't think it is very elegant, especially because it needs two additional variables. Anyway, it works...
