USB Serial input
starwolf73
There is two great projects for MIDI<->Serial Bridge already build for that. A simple arduino will work, take a look at:
HairLess
Work under Win, Mac and Linux
http://projectgus.github.io/hairless-midiserial/
https://github.com/projectgus/hairless-midiserial
See this example for Hairless integration
http://forum.arduino.cc/index.php?topic=79326.0
TTYMIDI
Work for Linux only with arduino Midi librairy
http://www.varal.org/ttymidi/
http://playground.arduino.cc/Main/MIDILibrary
SherwoodBC
Real Name: Duncan Smith
I just tried the Midi interface on a Teensy 3.1 and Teensy LC yesterday. Worked great, first try.
One problem however. The channel values are only 7 bits (0 - 127). I am already struggling with 8 bit resolution being steppy on the LEDs. 7 bit will only make it worse. I tried every configuration I could find, but 7-bit seemed to be the limit.
Or is there something I missed?
asm
Real Name: Allan Madsen
I will use this pcf8591 look it up, its a 4 x AD 8bit i2c chip
@sherwoodbc: Yes you missed something small ... MIDI is ~only~7b (0-127)
asm
Look at "map" in arduino ide.
