Fixture Editor - Add Lamp Type
lorenzoandreani
Real Name: Lorenzo Andreani
Post by lorenzoandreani » Mon Oct 10, 2016 1:39 pm
In fixture editor i do not see the lamp type "Msd Platinum 15r 300w"
You can add this lamp type?
QLC+ 4.10.4
janosvitok
Real Name: Jano Svitok
Re: Fixture Editor - Add Lamp Type
Post by janosvitok » Mon Oct 10, 2016 2:46 pm
I've thought it's a quick fix to add it, but it seems that the values are in two places, so besides adding this one value,
the code calls for a small cleanup as well...
janosvitok
Post by janosvitok » Mon Oct 10, 2016 3:01 pm
I was wrong, it was simple.I've added "MSD Platinum 15 R 300W" to git version.
lorenzoandreani
Post by lorenzoandreani » Mon Oct 10, 2016 3:04 pm
Ok, good
Might also be useful to add an entry in the combobox indicated "Not defined" to use if do not know the type of lamp or is not on the list
lorenzoandreani
Post by lorenzoandreani » Mon Oct 10, 2016 3:08 pm
I thought it would be useful to have a report with the energy consumption values ​​of the fixtures used in a show so you can know the total current load of the stage
