matrix vertical fall
Krsound
Real Name: Kyle Sims
Can we put vertical or horizontal on the vertical fall matrix , or could someone tell me how to code the matrix to do horizontal, because until there is an option to have rows and columns matrixes my vertical fall goes from left to right not top to bottom.
janosvitok
Real Name: Jano Svitok
Unless your matrix is too big, you can manually reposition heads in fixture group.
Can you post your qxw file?
Krsound
attached is the file
show.qxw
(1.01 MiB) Downloaded 62 times
