Custom chasers/sequences
Alv
Real Name: Alvaro Pelaez
A feature that I feel QLC+ is missing is the option to create chasers or sequences with 'live' modifications. For example, having a sequence that has a base colour with a flash of a secondary colour. It would be nice to have a widget similar to the Animation widget, where you can select a sequence/chaser that's already created and choose its colours/parameters.
bestdani
Real Name: Daniel
I agree to some extent, but when you use plain color RGB matrices as chaser steps (or together with matrices in mask mode) you can control the colors already very easily and flexible. I don't know any software / console that allows you to do this so far.
You can even achieve more chaser customization by using loopbacks with some trickery, but I also think that it would be very cool to have an option to have full access to control chaser / sequence steps live with faders for example since loopback device solutions are often rather time consuming to setup and they also create a messy workspace. ;-)
