command line scripts
How difficult would it be to isolate the QLC+ scripting functionality so that scripts could be run from the command line? I'm trying to write simple lighting scripts that use the ENTTEC Open DMX USB and QLC+ is the only program I know of that supports the device in Linux without a manually compiled kernel module. Thanks for the information!
I think you can do it via websocket, using the Web API: http://www.qlcplus.org/Test_Web_API.html
