I'm playing with my new APCmini and try to use the "custom feedback"-feature with QLC+. So i create a Button with a custom feedback (lower value 2, upper value 4) and run the Workspace. Now, the assigned Button of the APC is off which is a little bit irritating, cause wenn of, the Value 2 should be sent to the APC.
After the first press the Button blinks green (value 4) and after the next press the button is static green (value 2) which is ok.
Is it possible to send on start the Off/lower values to the feedback-device if custom feedback is defined? For the APC ypu can set the right buttons illuminated, for other devices, you can set motorfader to the right position etc.
AKAI APCmini ( and Co.)
Feedbacks are supposed to be sent even at startup.
You might just need to reload your project...
Ok. I just started with "Play" and nothing happens. I try the reload..
[Edit]
Ok, reloading the Project works but i think, this is a bit unwieldy. Sending the values on Play/Start/Whatever could be easier to understand (and to test).
[Edit]
