Screen scaling
hutje
Real Name: Robin
When I want to use a project from another computer, the screen resolution is different than the other computer. This causes scrolling bars in the screen.
Is it possible to add the feature when you change the resolution of the virtual console/frames the frames/buttons/faders will scale with it?
Another feature is give frames/buttons/faders color and control the transparency of the layer. Now I needed to make a .png which has a transparent layer.
I just made a user interface for the bcf-2000 but now I can only use it one computer with the same resolution.
