EFX relative Attribute
Can you describe how would you use it?
- Real Name: Louis Gutenschwager
Well when I'm doing a show and I want the efx to have its relative disabled before i go to it.
so Initial state would be right click disable or right click enable depending on what the default efx state is
While it is running it would be which ever I set to
when the efx is stopped or I switch to a different one it should change back to its default.
