Flash-Button for Submaster?
One little thing i miss: A flash-button for submaster-fader. Maybe as extra feature for the button widget or (harder to code) as component inside the fader widget. Is this possible?
- Real Name: Lukas
This is already possible with the loopback plugin. Please have a look at the attached workspace.
- flash submaster.qxw
- (3.39 KiB) Downloaded 67 times
- Real Name: Chris Laurie
Hi Siegmund
This does not quite work:
Set slider to 125
Press & hold submaster flash button - slider goes to 255 - that is good.
Release the flash button - slider goes to 0
Currently the script engine does not cater for reading a channel value and storing it somewhere to use later. I suspect on top of that it would also need the ability to execute a function (script) on the release of a button.
Set slider to 125
- Real Name: Lukas
You're right, sorry I just quick tested it with 0 as initial value.
Yeah, some additional features in the script function would be great. In the meantime, you could work around the issue with an additional fader:
- (4.05 KiB) Downloaded 85 times
