Fading slows down rgb scripts
prutseltje
Real Name: Rob Nieuwenhuizen
When use fade in or fade out in a rgb script the whole script slows down, even when the fading is done.
Create a rgb panel of 500 fixtures, use balls for example, set the speed to 50ms. Everything works as expected.
Now set the Fade in to 1s and the balls slow down.
OddSocks
Real Name: Tim Cullingworth
This is due to the fact that "fade in" is added to the duration. This is the same for all the timings in QLC+.
