QLC+ with Showtec DMX Node 2
thedesven
Real Name: Sven Lederle
Hey guys,
I´ve been using QLC+ for a long time with a enttec USB Pro interface.
Now I bought a Showtec DMX Node 2/Liteputer dp-e450 and thought it would support the ArtNet Protocol but it only supports DMX via ethernet.
Is there anyway to use this node with QLC+?
Greetings from Germany
Sven
PS: Here some links with info about the node:
http://www.liteputer.com.tw/product_detail.asp?id=492
http://www.notape.net/files/eqs4/dpe-45 ... fc2ab4.PDF
Hi, as far as I can tell, that device is not an ArtNet node.
I suppose it receives data from the network and convert it to DMX, but I have no idea how packets should be formatted.
If you can find the ethernet specs maybe we can see what can be done.
