Issue on mapping Akai APC40
Matteo Portaluppi
i have some problem with the channel number and midi signal of my Akai Apc40.
I'll explain, some midi channel number, when i press the physical button on the controller, are for example 186-187-188 ecc but the other is 4273-4274-12296 ecc, in this last case when i press the button on akai the midi signal is no recognized by Qlc+ but if i test the controller with MidiOX it's all ok.
can someone help me?
Alessandro Grechi
Probably your channels are different from the ones in the default profile. You can create a new profile if you want, but your APC40 should be working also with a wrong channel name...
Diego Quintanilla
Real Name: Diego Quintanilla
Hi , I'm from Argentina , sorry for my English , I have the same problem with an Akai APC20 , I can not create a new profile ,¿can someone help me?
Diego Quintanilla wrote:Hi , I'm from Argentina , sorry for my English , I have the same problem with an Akai APC20 , I can not create a new profile ,¿can someone help me?
Out of this topic: you posted this question 4 times on every forum. I'm warning you. Keep on acting like this and I'll ban you from the forum.
Such a useless behaviour.
Those large numbers mean midi channel > 1, see online help.
For apc to work, you need to set midi channel to 1-16 in the midi plugin settings.
