When using a chaser as a step inside another chaser, the *child* chaser will inherit the fade times from its *parent* chaser if you select *per step* as fade speed.
A nice feature would be that you can choose to still keep the child chaser's fade times, although the other steps in the parent chaser use a per step fade time, defined in the chaser.
Something you could do is create a checkbox *Keep fade time*, next to the *Infinite* checkbox or so.
This seems like a useful feature during lighting set-up, since it is easier to quickly change the fade times in the chaser than go to every scene individually and change it there.
Would anyone else be interested in this feature?
If so, I would be willing to implement this.
Cheers,
Dylan
