AKAI APC mini - Button-LED
matthe_tp
Post by matthe_tp » Thu Nov 20, 2014 9:15 pm
Hallo, I'm from germany, my english is not so good, sorry.
I have a problem with the Button-LED on AKAI APC MINI. The LEDs turn on but not off. Can anyboby help me?
Maikel Boerebach
Post by Maikel Boerebach » Mon Dec 15, 2014 2:01 pm
I had the exact same issue. See this post for the solution:
http://sourceforge.net/p/qlcplus/discus ... /?limit=25
Maikel Boerebach
Post by Maikel Boerebach » Wed Dec 17, 2014 11:14 am
Since i compile all the qlc versions for myself i could send my working version. However I have OLA disabled, so if you need this particular function, you will have to compile QLC from GIT on your own.
Alessandro Grechi
Post by Alessandro Grechi » Wed Dec 17, 2014 10:15 pm
Hi Maikel,
I read on the other thread you managed to change led colors to APC buttons. Could you please share your work? I would be pleased to try it also on mine!
Thank you!
Maikel Boerebach
Post by Maikel Boerebach » Sun Dec 28, 2014 2:51 pm
Hi Allesandro, sorry for the very late reply.. I forgot to check the thread for a while.
I used Janos' ideas and adapted them to my needs, since I wanted a bi-color-feedback: Red(Off) Green(On).
I managed to do this by editing the lines in the file "midiprotocol.cpp".
This is the part I have changed in lines 138 to 145:
else if (channel >= CHANNEL_OFFSET_NOTE && channel (channel - CHANNEL_OFFSET_NOTE);
*data2 = DMX2MIDI((value==0) ? 3 : value);
In the 6th line "3" represents the midi-value for the On state. When you play with these you can change the colors to green,red,amber(orange). And you can choose to let the LEDs flash. In the other thread i have posted a text-file which describes which values you need to get certain colors.
For your convenience i have also attached the midi protocol.cpp file.
If you replace it in your git directory you will just need to recompile.
As i have mentioned, this also works for the launchpad, however the colors are a bit different.
Cheers,
Maikel
midiprotocol.cpp
(5.44 KiB) Downloaded 164 times
msccd
Re: AKAI APC mini - Button-LED
Post by msccd » Sun Dec 28, 2014 2:51 pm
Maikel Boerebach wrote: This is the part I have changed in lines 138 to 145:
Hi Maikel,
thank You very much for Your work. I used Your midiprotocol and it worked fine on the mac (to be honest it's a virtual machine I set up for compiling). Now I was up to create the dmg file to install it on my macbook, which will be the machine where I'll work with QLC+.
I followed the HowTo at https://github.com/mcallegari/qlcplus/w ... uild-HOWTO , but I got errors. Some framework-files have been missed. I got em out of the installed QLC+ Version (downloaded the original install-dmg), but there ist still one file missing:
error: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/install_name_tool: can't open file: /Users/admin/QLC+.app/Contents/Frameworks/QtSerialPort.framework/Versions/5/QtSerialPort (No such file or directory)
make[1]: *** [install_LIBQTSERIALPORT_ID] Error 1
make: *** [sub-macx-install_subtargets-ordered] Error 2
Installation error. Aborting package creation.
Now I wonder where i can get the missing files from, because even in a "normal" installed QLC+.app is no QtSerialPort included. Could someone help me out please?
Just in case You need to know what I've done, here my HowTo:
1. set up new and clean OS X Yosemite VMware just for the compiling
2. installed latest versions of apple Xcode via appstore, command line tools, QT and MacPorts
3. Port-Update
sudo port selfupdate
sudo port install libftdi0 pkgconfig libmad libsndfile portaudio liblo fftw-3 ola
4. Download latest QLC+ sources
git clone git://github.com/mcallegari/qlcplus.git
5. replaced the midiprotocol.cpp with Maikel Boerebach's version
6. building
export PATH=$PATH:/users/admin/Qt/5.5/clang_64/bin
cd qlcplus
qmake -spec macx-g++
make
7. install
make install
8. make dmg
./create-dmg.sh
Alessandro Grechi
Post by Alessandro Grechi » Sun Dec 28, 2014 6:36 pm
Thank you Maikel, I'll try it asap with my APC40 and APC20, they should both work in similar way, I hope.
In my opinion the best result would be to have the button colored in red only if there is a function attached to it, and leave it off otherwise... (this is the behaviour I saw in other software)
Ronnie Roselli
Post by Ronnie Roselli » Mon Dec 29, 2014 6:37 pm
Thank you for your answer, but I can not figure out where to find the file "midiprotocol.cpp" in my computer (windows7 64 bit).
I downloaded your file already modified and thought I replace it with the present in my computer, but I realized that you can not do.
Can you explain exactly how and where I have to replace or edit this file "midiprotocol.cpp"?
Excuse me, but are not as experienced in programming ...
Jano Svitok
Post by Jano Svitok » Mon Dec 29, 2014 11:49 pm
you need to follow https://github.com/mcallegari/qlcplus/w ... uild-HOWTO and when it tells you to download sources, do that, and replace file plugins/midi/common/midiprotocol.cpp with the one provided above. Then follow the guide again.
In other words, you need to create your very own installation file from the (modified) sources, which is a bit complicated process.
Ronnie Roselli
Post by Ronnie Roselli » Tue Dec 30, 2014 12:33 am
Thank you but it's really too complicated to solve my problem!
Per Massimo Callegari:
è possibile risolvere il problema ormai noto e a quanto pare risolto con una patch o un aggiornamento? Mi sto pentendo di aver preso l'unico controller che non funziona come dovrebbe!
