Wiki update
Joep Admiraal
I did an update on the wiki in my own repository.
But I don't see how I can get that change into the mcallegari repository.
It seems like the wiki part of Github does not support pull requests.
How should I proceed?
Jano Svitok
I merged your commit. Most probably the way to go is to create either issue or a post here. Then either Massimo or me have to merge it manually, unless Massimo gives you commit access :)
