4.6.1 src compile issues on raspbian
lcslouis
Hello I just got a raspberry pi it is running raspbian and I am trying to compile 4.6.1 and I am getting this error.
make[2]: Entering directory `/home/pi/qlcplus/qlcplus-4.6.1/ui/src'
g++ -c -pipe -Werror -Wno-unused-local-typedefs -O2 -D_REENTRANT -Wall -W -fPIC -DQT_WEBKIT -DQT_NO_DEBUG -DQT_SCRIPT_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtScript -I/usr/include/qt4 -I../../engine/src -I../../engine/src/audio -I../../plugins/interfaces -I../../webaccess -I. -I. -o vcbutton.o vcbutton.cpp
vcbutton.cpp: In member function âvirtual bool VCButton::loadXML(const QDomElement*)â:
vcbutton.cpp:839:76: error: call of overloaded âenableStartupIntensity(double)â is ambiguous
vcbutton.cpp:839:76: note: candidates are:
vcbutton.cpp:538:6: note: void VCButton::enableStartupIntensity(bool)
vcbutton.cpp:548:6: note: void VCButton::enableStartupIntensity(qreal)
At global scope:
cc1plus: error: unrecognized command line option "-Wno-unused-local-typedefs" [-Werror]
cc1plus: all warnings being treated as errors
make[2]: *** [vcbutton.o] Error 1
make[2]: Leaving directory `/home/pi/qlcplus/qlcplus-4.6.1/ui/src'
make[1]: *** [sub-src-make_default-ordered] Error 2
make[1]: Leaving directory `/home/pi/qlcplus/qlcplus-4.6.1/ui'
make: *** [sub-ui-make_default-ordered] Error 2
Massimo Callegari
Moved to the development thread.
If I remember, this has been fixed after 4.6.1.
