QLC 5 Compilation Error
Hockeyman271
Real Name: Stephan J Pivirotto
Post by Hockeyman271 » Mon Apr 17, 2017 7:59 pm
Im using windows 7, have Qt 5.8.0 and mysys64 installed. here is the version of Qt i have installed:
I was able to compile qlc but when i go to launch the application from C/qlcplus/ it is throwing me the error below.
I have been following this tutorial
https://github.com/mcallegari/qlcplus/w ... -Build-Qt5
I saw this section on the old way to compile for windows:
Do you still need to do these two steps before attempting to launch the software? installing MinGW and Qt.
any ideas? I have tried searching around the web for the issue but i couldn't find the same problem anywhere....
janosvitok
Real Name: Jano Svitok
Re: QLC 5 Compilation Error
Post by janosvitok » Thu Apr 20, 2017 9:30 am
Try to find the mentioned dll file somewhere in the QT directory, and copy it to QLC+ directory.
Hockeyman271
Post by Hockeyman271 » Thu Apr 20, 2017 8:45 pm
Found it!!
C:\msys64\mingw32\bin
I ended up having a couple fo DLLs missing:
libicuind57
libicuucd57
libicudtd57
libpcre16-0
copied them all to C:\qlcplus\
and the program started up!!
Thank you
