Hi Everyone
i'm try to limit the art net frame rate with
[HKEY_CURRENT_USER\Software\qlcplus\Q Light Controller Plus\mastertimer]
"frequency"=dword:0000001e
but the min value is 30 frame/second
my cheap art-net interface works fine with 15 - 20 frames/sec
could change the software and insert 2 new keys
1: limit dmx channels (for example 200)
2: limit art-net frame rate (and not the main process)
Thank's
limit Art-Net frame rate
http://qlcplus.org/docs/artnetplugin.html
see Transmission Mode in Configuration. That way you can limit # of channels transmitted (i.e. trailing zeroes are not transmitted).
- Real Name: Maurizio Ambra
thank's for your reply
I know that configuration, but if my ip changes i'll setting every time "Partial trasmission"
becouse 512 dmx channels generete too match latency, i'm try to use sequencer and sincronize audio and lighting.
would you insert into TODO LIST
kay parameters for artnet sending like entec usb
enttecdmxusbopen --> frequency
enttecdmxusbopen --> channels
thank's from italy
thank's from italy
